Professional Audio
Active speaker 250 w
Gazagne
Hi, my speaker sounds low although I turn it up. Can you help me?
wilson josé tecnico
friend that fault can be caused oh the amplifier outputs are burned oh the speaker coil measure them with the multimeter on the 200 ohm scale you should dial 3.90 oh 4.5 ohms in case it is 4 ohms if it is 8 you must dial 7.8 oh 8.5 ohm
