Professional Audio
Is there a power difference between an 80w amplifier and a 100w amplif
purplevice
Hello people, I comment my doubt. I have a Technics SA-EX320 (quite old) synthesizer that supposedly rolls 80 + 80, in other pages they say it rolls 40 + 40, and in other 70 + 70, but suppose it rolls 80 + 80. Now I want to buy an ampli that rolls 100 + 100, the question is .. Will there be a difference in power? (would it sound louder, so to speak) the 100w compared to the 80w? They are 20w apart (assuming the Technics rolls 80 + 80, if anyone knows how much it throws, please tell me) and I want to know if those 20w are noticeable .. I await your answers friends, thank you very much!
romaci2005
romaci2005
4.485
The Technics SA-EX320 amplifier delivers 80 Watt RMS per channel with THD harmonic distortion from 0.8% to 8 Ohm There is little difference between the 80W RMS amplifier and a 100W RMS amplifier. To really notice the difference and worth the investment, you should use a 160 Watt RMS amplifier per channel at 8 Ohm in the vintage category this could serve you http://audio-database.com/SANSUI/amp/au-20000-e.html In the category, professional power amplifier, this amplifier can serve you (200W RMS per channel at 8 Ohm) https://www.sonovente.com/es-es/crown-xli-800-p37124.html Best regards
