Cordial greeting, friend should check the transistor lines to see where the activation signal comes from and what is on that path or line and to be sure it would be good to remove it from the board and measure it outside while checking the transistor reference , this circuit could be like the one of the PC that activates with the temperature, if it follows the line of the transistor, check if it reaches a temperature sensor that is in the heatsink, you can also verify the fan on the other hand to see if it is ok. regards
