Professional Audio
build 300w amplifier module
martinarmando
Good day. I burned the amplifier card for a bheringer b300 cab. As it has 4 integrated circuits lm3886 and I don't get them I would like to make or install a new card. I accept any suggestion or indication. thanks
ndarz
ndarz
826
Hi, what voltage is the source you have? to see how far it can be done with that source.
Victor E
Victor E
65.783
300 watts with lm3386? Hummm
PASSTRAN eci_twi
300w but adding all the power of each lm3886 each has a power of 60w and there are 4 which would give a total power of 240w a little far at 300w that says
Victor E
Victor E
65.783
It does not give it, it must be pmpo or musical power. Using 2 in bridge we take 70w rms x 2 = 140w and with good temperature in the heatsink.
PASSTRAN eci_twi
but I think the lm3886 can't work in bridge mode
Victor E
Victor E
65.783
why not?
Victor E
Victor E
65.783
https://www.digikey.com/reference-designs/en/audio-amplifiers/106 here is one of the many circuits in bridge
PASSTRAN eci_twi
I am not very sure but I had read this in a forum dedicated to lm3886 and they claimed that lm3886 could work in parallel but not in bridge mode I think they have a limitation
PASSTRAN eci_twi
in the datashet many diagrams appear but there is not one where it is in bridge
http://www.ti.com/lit/ds/symlink/lm3886.pdf
Victor E
Victor E
65.783
any correctly polarized amplifier can work on bridge, in this case the circuit is class ab.fin of the post for me
See here https://www.digikey.com/reference-designs/en/audio-amplifiers/106. End of the post for me. Cheers
Amperio7
Amperio7
543
Victor E, you're right. Texas Instruments, Application Note AN-1192 Overture Series High Power Solution.
http://www.ti.com/lit/an/snaa021b/snaa021b.pdf.
Amplifier bridge, page 10, diagram 5.2.1. Parallel amplifier, page 13, diagram 6.2.1 and can also be a parallel bridge page 20, diagram 7.2.1.In the PDF are all the calculations and circuits, for proper operation.
Merry Christmas! and best regards.
PASSTRAN eci_twi
hello friend a very good option is to make a new amplifier card but instead of the lm3886 do it with tda7294 that works with the same voltage of the lm3886 uses very few external components in addition to the tda7294 e layers of giving 80w and the lm3886 60w by what you will have a little more power greetings friend
