Professional Audio
Replacement mosfet k16a60w
mario256
good morning I have a doubt with this MOSFET K16A60W I burn and I do not get the original and they sold me as a replacement 20n60 is correct as replacement the mostet is in a sony audio system
Victor E
Victor E
65.783
The K16A60W is a 16 amp 600 volt 40 watt mosfet. The 20n60 is a 20 amp 600 volt 370-416 watt high power mosfet. that is, it is bigger in power than the one that has
Milflo
Milflo
1.386
Comparing the MOSFET data sheet, it is a correct replacement. If it is short, you should check the resistance of metal oxide that is connected to the SOURCE pin (S) of the MOSFET and is connected to GND. Also the oscillator and associated capacitors. Do you have the diagram? What is the model ?.
mario256
AUDIO SYSTEM SONY MOD CNC-ID-C-12772 main SM509A08331
Victor E
Victor E
65.783
and now, what is the doubt?
mario256
I need the diagram
Victor E
Victor E
65.783
Close the question and open another one asking for the diagram. Place the model of that device well because the numbering you gave does not appear on the web.
