Professional Audio
progaramar digitech studio dbx quad4
El balderas
Good day! I have a digitech studio quad 4, without battery, I put one but it is deprogrammed, if someone could support me to do the programming I would greatly appreciate it. Only the screen flickers. Beforehand thank you very much.
GABRIEL MUÑIZ
Hi Baldeeras In the following link, download the manual: ftp://ftp.digitech.com/pub/pdfs/Discontinued/Manuals/StudioQuad%20Manual.pdf On pages 37 7 38 it tells you how to proceed with the programming. I clarify that I do not have an equal team, but regularly following the instructions in the manual you manage to solve these kinds of problems. Luck
Ángel Morales
In case you can not do a factory reset you will have to do a search in the networks or direct support of the manufacturer to be able to obtain the SYSEX file that corresponds to the programming banks of the device, via MIDI the dump is done towards the same (you should have backed it up before putting a new battery). Check if it can be reset to factory state with the manual, banks are probably recorded in ROM (some devices do not have this resource). Page 36 of the manual. Quad4_original.pdf [570.35kb]
El balderas
Thank you very much, indeed the sound bank is in the memory of quad 4, the manual has been very helpful. Regards.
