The amplifiers are designed to give a flat response across the entire frequency range. The additional resource to obtain only low is "cross", "limit", discriminate medium and high to a specific range with a cross-over. It depends on the speakers you use. If you can specify more specifically which speakers you are going to use with this would be the possible suggestion.
