Professional Audio
Peavey XR684F amplifier burns drivers
Oswaldo Tercero
This amplifier arrived at the workshop with two of the drivers open from base to emitter, one negative and one positive. The numbers of the transistors are: A1837 and C4793, I proceeded to change them for originals, not generic, but when turning on the device one of the negative transistors gets quite hot, I replaced the two power that are connected to said driver, but the same. Before that I took the time to check one by one and raised the components associated with the whole output, all good. Please wait for suggestions, thanks.
EVELIO RIOS H
Oswaldo here you download the diagram: https://www.yoreparo.com/audio/audio/preguntas/1284815/diagrama-del-xr-684-peavey-amp-de-poder Friend, what is the voltage between base and base of the drivers?
