Professional Audio
How to set standby current preset on a yamaha cr220
marcelo viviano
I need to know the procedure to adjust idle current in a YAMAHA MODEL CR 220
Jose Guillermo Valderrama
Adjusting standby current of a yamaha cr-220 VR703 Left channel between the TP1 and TP2 test points must measure 33mv, (adjust with this preset.) VR 704 left channel TP3 and TP4 in the amp. pag 11 bottom box you will find the details and the drawing where the TP s are located in the next link can download the manual. https://www.electronica-pt.com/esquema/audio/yamaha-audio/yamaha-cr-220-41647/ regards
