What the electronic ney partner says is very true, you have to verify the supply voltage of those integrated which is symmetric, positive and negative voltage plus ground. The two voltjaes must be the same. It can be 12 volts positive and 12 volts negative - but I would recommend that you check the card or output module and then the pre-amplifiers are checked so that you are sure that the outputs are good first.
