ok thank you friend I thank you for your contribution it makes sense what you just wrote to me
Now tell me with that player that you say you can use the pich and the effects thanks for responding
if you read again you will notice that it says at the end of my answer Ha and of course zero pich that is, it will only serve you practically the power supply and RCA jacks of your dennon, and if you can adapt the large play, next stop buttons etc. with cables to the module
but the module has no effects or pich. as I mentioned before.
don't forget to rate answers right or wrong but value
Thank you.
Thank you very fine friend of your part and you answered my question you are a master in these things thanks greetings from guatemala
