Professional Audio
Evo 410 handy novik - burnt plate
CristhianAlexis
Greetings to all! Again here asking for help. I brought this equipment and unfortunately I have a part of the amplifier board PPA410M-PCB02-V1.3. He burned the tracks and burst a condenser. I need to rebuild it but I don't get the diagram. Someone can pass a photo of the plate to copy it. and if someone had the diagram it would be fabulous. From already thank you very much. IMG_20180212_163515.jpg [1.58MB]
romaci2005
romaci2005
4.485
https://www.yoreparo.com/audio/audio/preguntas/1532629/solicito-diagrama-evo410-handy-novik > The PCB board of your computer is a class D amplifier. > With the integrated circuit number, you can search the datasheet to obtain the schematic diagram. Or you can also contact the manufacturer: https://www.novikneo.com/contact.php Best regards
CristhianAlexis
Hello! Thanks for answering. That post is closed. and they didn't publish the diagram. I can't find any solution for me there. Or is something happening to me?
salomeco
salomeco
Hello good I need the bottom part since I couldn't get the diagram thank you I'm also here to help thanks
Mauro Fernando Fontao
Hi. I have a conolita like that and not me. The bluetooth usb module works. The. Problema.es.que no current comes from where the module is connected to the mixer plate. The module works, I test it by connecting it to a source. 12v and 250 mAmp I think ... It is. Lo. I had on hand. It works but it seems that the source makes interference or something like that because a buzz is heard. Could you connect on the ogre side of the board? What source would lempodria put? Thank you.
DLS83
DLS83
5
Hi Salomeco, I would like to know what value the capacitor C13 is, the Resistance that is next to it, since they brought me a team of these from novik EVO 410 handy and that capacitor completely burst along with the resistance burning the base of the plate where the resistance is located. Thank you in advance for the answer
pebarquett
Dls83 c13 is 22uf by 50v. R5 is 10ohm 1/4 w. If you can, you could pass me the value of c25. I'm also with one of that console. Thanks in advance
