Professional Audio
Diode 1N5404 can be replaced by 1N5402
manuel 10
Diode 1N5404 can be replaced by 1N5402 because I see that it had to be 16 vol but it is more than what I expected is sending 40 and vol. Vol. Which I recommend is for an amplifier of 30 watt 15 per output
ricbevi
ricbevi
17.055
If you can, if the application is for voltages below 200V, it is the maximum safe operating voltage recommended by the diode manufacturer. The 1N5404 is identical but can work up to 400Vac.
oscar yasinski
HELLO FRIEND, THE 5402 WORKS UP TO 200V AND THE 5404 WORKS UP TO 400V THE REST ALL THE SAME 3A / 200ap. SO EVERYTHING DEPENDS ON THE VOLTAGE THAT WORKS AND ITS PEAKS. REGARDS .
