Professional Audio
Replacement for 2sc4081
Djzard20
I found the damage of a Casio musical keyboard. But I can't find a replacement or equivalent. The transistor is a 2sc4081
manoloack
manoloack
548
2SC3392CY 2SC4076 2SC4081 2SC4181 2SC4181A 2SC4413 2SC3392DY BSS99 FMMT38A FMMT38B FMMT38C FMMT614 KSC1623G KSC1623L KST1623L6 KST1623L7
Seb12
Seb12
967
Companion MANOLOACK, I know that I have usurped your solution and that it is correct for that reason I am giving you my positive vote already, but teaching the partner from where we get the answers we will make it more independent
A hug and see you soon
manoloack
manoloack
548
You are right that it is better to teach how to do the searches, I have put links to that page before, surely this is not the case, but I have encountered cases that did not know how to use it, especially if there was no direct equivalent and they had to retouch the values for the search.
Greetings.
Seb12
Seb12
967
Have a good weekend, a fellow hug
Seb12
Seb12
967
Manoloack you can think of an alternative with the partner's problem.
You had named something to touch up that I don't know.
Please if you can you look and help us
A hug
manoloack
manoloack
548
The main problem is to find one that Djzard20 has on hand, I suppose you will have to make a list with all the equivalents and then look for them in the workshop, I would start with the list on the alltransistors page, in the replacement search a table with Some of the features already set, Lugo looking at the datasheet would add or modify the missing ones, finally take out the equivalents by first modifying the Caps (encapsulated) for example sot323 sot23 sot89 sot223 to92 and then slightly increasing the voltage values.
Seb12
Seb12
967
We should no longer wait for your comments. MANOLOACK will look for you whenever you need a replacement
Thanks for contributing
Seb12
Seb12
967
So you don't need to always ask yourself what they would be I use this link that I share here https://alltransistors.com/en/search.php?search=2sc4081 same here they answered your question 9 years ago A hug and see you soon YOU WILL ALWAYS FIND BELOW RELATED QUESTIONS this is where I sent you the photo, not the link Most of the questions I need, but I don't lie to you 99.8% and someone asked him and they answered him. A great tool that almost nobody knows on the page
Djzard20
None of the replacements are sold at my location. so I decided to do a search of different npn transistors to try to find one with specifications similar to those of 2sc4081 and I found only 1. (PMSS3904) I feel tempted to replace it with it. but I don't know if the result of the test is that the PMSS3904 burns or causes other damage to the circuit
Seb12
Seb12
967
Look at the comment of MANOLOACK, the partner truly understands more than me in alternatives, modify the list of the link with the changes proposed by the partner.
Surely something you find
I don't want to make more mistakes so I'll be honest I wouldn't know how to modify it
If in doubt, write and at least help you asking for assistance
A hug and thanks to MANOLOACK
