Professional Audio
problems with lsv amplifier
jose luis machado gonzale
Blessings to colleagues I got an amplifier of Chinese technology which arrived with the inflated filters of the 3300uf 35v source I proceeded to change them and turned on perfectly but only one detail remains to activate the re-lay about 10 minutes after that period of active time and it sounds good its two channels I appreciate your contribution to solve this failure plate chassis is AV 727
ok I check and I thank you
EVELIO RIOS H
Jose checks the circuit, the source that sustains it and the voltage that activates it.
greetings evelio rios if it was exactly the voltage that powers it, I proceeded to check the voltages that came to said re-lay and the fault was a 220k resistor that feeds the transistor c9014 was faulty thanks for the collaboration
