Professional Audio
Integrated ca3080e amplifier pv-1200 replacement
bersa
bersa
13
hace 6 años
hace 6 años
HELLO GOOD DAY FOR ALL BLESSINGS. FRIENDS I HAVE PLANT PEAVEY PV-1200 I HAVE DETAIL WITH THE FAN IS VERY ACCELERATED, I REQUEST THE DIAGRAM WHERE THIS STAGE AND THE CA3080E SOMEONE WHO CAN SUPPORT WITH EQUIVALENT GOOD IF THERE IS A EQUIVALENT, WITH THE DATA ?. ALREADY REPAIR THE 2 CHANNELS AND THEY ARE POLARIZING PERFECTION. IT'S ONLY THAT DETAIL. I APPRECIATE YOUR COLLABORATION.
jomi
jomi
38.143
hace 6 años
hace 6 años
You can use ECG90, LM3080, LM3080H
bersa
bersa
13
hace 6 años
Thank you, my friend, I will try tin and you will have the diagram of the pv-1200 in the stage of the venrilator is very accelerated, blessings
Quintero4hson
hace 6 años
hace 6 años
Hello good morning friends. See if this circuit works for the fan, I don't know what voltage your fan works with. peavey_pv-1500 (1) .pdf [97.79kb] Greetings from Valledupar Colombia.
romaci2005
romaci2005
4.485
hace 6 años
hace 6 años
schematic diagram peavey PV-2000, stage FAN on page 14 https://elektrotanya.com/peavey_pv-2000.pdf/download.html#dl
