hace 6 años
Hello, I bought a Smart TV Ken Brown model KB32S2000SA and I want to connect it with a Home theater Thonet & Vander 5.1 model Veel, 250 W (rms). The problem arises that now the TVs do not come with many outputs and according to the manual as audio output of the TV figure SDPIF (digital) and the home is totally analog. The funny thing is that on TV there are also component outputs, stereo audio and video (rca) and also a mini plug for headphones, I tried the earphone connected to the rca inputs of the home (aux) and nothing, I also tried the rca stereo outputs to rca (aux) and nothing ... those stereo outputs had them connected to the dvd and transmits ... ahhh ... as I write I realize that if they come from the dvd they are not output ... Well ... I have the headset and the coaxial output (common NOT optical) ... but I have no cable, the issue is that even buying the cable should transform it to analog. In the TV manual it says 2x6 w audio output. It might not give you the impedance of the headphone output to move such a monster? Or simply have to send to check the home socket? or I buy the coaxial cable SDPIF and a converter from digital to analog 5.1 ??? Let's see if they can give me a hand? Thank you.!
