Professional Audio
Add 2 speakers
wolverine30000
hace 6 años
hace 6 años
I have a minicomponent of two speakers, each output is 500w and 6 ohms. I want to connect two extra 500W speakers in parallel, how many ohms should they be so as not to damage the minicomponent?
hace 6 años
hace 6 años
Hi. What is the impedance that the equipment accepts? The combination of speakers / blafes in series or parallel must be the one accepted by the team so as not to burn it. Regards
wolverine30000
hace 6 años
It is 500w and 6 ohms at each output
hace 6 años
Then you should not over 6 ohm. The combination of speakers should give you this impedance. As for the power, the sum of them depending on their configuration must be 500W or higher. (if you will work it to the fullest)
wolverine30000
hace 6 años
Thank you for your prompt responses, I would like you to tell me how many ohms my speakers should be and how to connect them.
hace 6 años
It is as I said. The total impedance must be 6 ohm. How to connect them we could not know since we do not know the others you mention.
wolverine30000
hace 6 años
hace 6 años
I want to connect them like this
hace 6 años
Thus you will burn or force the ampli. Its output impedance is 6 ohm and you put them in parallel will have a little more than 4 ohm. You should always keep the same impedance.
wolverine30000
hace 6 años
And if they were more than 8 ohms ?, I could connect them in parallel
