Exactly, check "very carefully remove the amplifier transistors and measure in continuity noq not yet short in the voltage input since this uses a symmetric source as Mr. Victor commented it could also be some driver transistor or some diode in short since as I have been committing and I hope I understand well the fuse blows when connecting the amplifier stage
Could you tell me how to measure diodes and capacitors to know if they are in correct and erroneous operation, I would like to add photos but I do not know how ????
Yes, the fuse burns when the audio output power is connected, there are two cables, one is the one that feeds the mixing panel, where the microphones are connected, when connecting only that cable the console turns on and does not burn the fuse even It recognizes the microphone since it shows activity of the LEDs, but the cable that feeds the audio output when connected is the one that burns the fuse, makes a strange noise the transformer and turns off because the fuse has already blown. today check and there was a 5w r39j resistor in short and a transistor c3856, replace them but keep burning the fuse
With respect to the goddesses in the multiteste, whether in diode scale or resistance, you should measure yourself under one-way ohm, xom the capacitors or capacitors if they use the electrolytic, that is, what appear to be cylinders is measured with a capacitor of not having it, it can be measured with A multitester analogue on a 10x scale will notice that the needle marks and goes back to zero, but if it looks dry, so it changes, do I check the output transistors? It is very frequent these are damaged
