Professional Audio
Real power?
wolverine30000
hace 6 años
hace 6 años
Please can someone tell me how many RMS watts this 12-inch horn is because it only brings the pmpo power.
Victor E
Victor E
65.783
hace 6 años
calculate about 90 real watts or rms.
wolverine30000
hace 6 años
Mmmm I thought it was about 600 rms
AllSolutions.CL
hace 6 años
hace 6 años
There is no accuracy but in the university we divided by 8 and it was a fairly realistic approximation to the measurements. PPMO / 8 RMS approx. 950ppmo = 120 rms approx. Regards
Victor E
Victor E
65.783
hace 6 años
hace 6 años
There are no exact calculations in PMPO, since this is a commercial power, and each manufacturer makes its own calculation at its convenience, the same goes for the audio power amplifiers. I have seen 2400 watt pmpo amplifiers and the real power did not reach 24 watts per channel. the same happens with speakers or speakers, do not buy when it comes only indicated the power pmpo and not in rms. greetings
wolverine30000
hace 6 años
Thank you for your answers.
I tell you that connect the speakers to outputs of 550w RMS per channel would be like 225 RMS and almost not heard, then connect them to 500w RMS per channel and they sound very good but when you get to the maximum a slight smell is perceived as burned .
I want to connect a resistor to protect the horn but I don't want its volume to decrease how much the resistance should be?
Victor E
Victor E
65.783
hace 6 años
Unfortunately that is not possible. It will have sound distortion. Get appropriate speakers for that equipment
