Lexen LXA251 specifications
> 4 Ohms Stereo - 125W x 2 8 Ohms Stereo - 80W x 2 8 Ohms Bridge - 250 W Two Power Amplifier bridge channels
Forced ventilation with low noise fans
Power indicators, Signal, Clip and protection
Output with Speakon
Frequency Response …… .20Hz - 20kHz (± 0.5dB) Signal to Noise Ratio …………………………… ..102dB
Total harmonic distortion ………………………… 0.1%
Balanced Input Impedance ……… ..20K Ohms
Unbalanced Input Impedance …… 10K Ohms
Entry Level ………………………… .. + 4dB
Damping Factor….> 200 (f = 1kHz 8 Ohms)
Short Circuit Protection ………………………… .Yes
AC / DC protection ………………………………… ..Yes
Temperature Protection ……………………………… Yes >
To use the amplifier in bridge mode:
1) place the amplifier switch on bridge
2) enter signal only on channel A, (no signal must be input on channel B)
3) Connect only 1 8 Ohm speaker to the 2 red terminals of the amplifier
The + terminal of the speaker is from channel A because it is the one in phase with the input.
Best regards
