Professional Audio
Any alternative for transistors C6011A A2151A?
colomadax123
hace 6 años
hace 6 años
gyeraldh
hace 6 años
hace 6 años
You can replace the 2SC6011A with the 2SC3320 = 13px, 2SD1313 = 13px, MJW3281A = 13px or You can replace the 2SA2151A with the [url=https://www.el-component.com/bipolar-transistors/mjw1302a] MJW1302A = 13px or MJW1302AG
nestortransistorelectroni
hace 6 años
hace 6 años
C6011A replacements: Transistor or equivalent selection results ↑ Type Mat Struct Pc Vcb Vce Ic Ft Hfe Caps NJW3281G Yes NPN 200 250 250 15 30 75 TO3P NJW1302 If NPN * PNP 200 250 15 30 75 TO3P If NPN 230 350 15 35 80 TO3PBL TO264 [url=https://alltransistors.com/transistor.php?transistor=49786] MJL3281A Yes NPN 200 260 15 30 75 TO3PBL TO264 MG6331-R Yes NPN 300 260 260 18 60 70 TO3P MG6331 If NPN 300 230 230 18 60 70 TO3P MG6330-R If NPN 200 260 260 15 60 70 TO3P MG 6330 If NPN 200 230 230 15 60 70 TO3P 2SC6011A If NPN 160 230 230 15 20 50 TO3P 2SC5359 Yes NPN 180 230 230 15 30 55 TO3P A2151A replacements: ↓ Type Mat Struct Pc Vcb Vce Ic Tj Ft Hfe Caps 2SA1987 Yes PNP 180 230 230 15 150 30 55 TO3PL 2STA2120 Yes PNP 200 250 250 17 150 25 80 TO3P Yes PNP 160 230 230 15 150 20 50 TO3P [url=https://alltransistors.com/transistor.php?transistor=65874] MG9410 If PNP 200 230 230 15 150 35 70 TO3P MG9410-R Yes PNP 200 260 260 15 150 35 70 TO3P MG9411 If PNP 300 230 230 18 150 35 70 TO3P MG9411-R Yes PNP 300 260 260 18 150 35 70 TO3P MJL1302A Yes PNP 200 260 15 30 75 TO3PBL TO264 MJL4302A Yes PNP 230 350 15 35 80 TO3PBL TO264 NJW1302 If NPN * PNP 200 250 15 30 75 TO3P NJW1302G Yes PNP 200 250 250 15 150 30 75 TO3P
