Professional Audio
Amplified horn damaged EVL ES18-DSP
Manuel ito
hace 6 años
hace 6 años
Hello, I have gone several EVL ES18-DSP amplified speakers, which are damaged from the switched source, the 8-pin oscillator circuit is damaged, which thunders and I cannot find the number if someone knows something I would appreciate it please, it is marked as CI 102P Y If you have the number, keep it also, lest the same thing happen to you later and don't get the number.
elmeneao
elmeneao
115
hace 6 años
what number?
Manuel ito
hace 6 años
The number that comes in the integrated circuit in the card is marked as CI 102P is an integrated eight-pin is that of the switched source.
elmeneao
elmeneao
115
hace 6 años
Yes, and what do you want to know?
usuario123pc
usuario123pc
1.096
hace 6 años
I guess and obviously that the license plate or silkscreen found in the ic (integrated circuit). I don't have the license plate, I'm sorry Manuel.
Manuel ito
hace 6 años
If I dedicate the number that comes in the circuit, thanks user123pc
Manuel ito
hace 6 años
hace 6 años
this is the circuit that is damaged all remain so
usuario123pc
usuario123pc
1.096
hace 6 años
You would have to opt better for a source that demands the consumption that the audio amplifier needs, greetings.
