Professional Audio
Info about UCOA ES 60 amplifier
ken09
ken09
2
hace 6 años
hace 6 años
Good, I would like to know if you can help me get information about this brand, UCOA solid state amplifier ES 60 and its utilities, Example: in which outputs are the speakers etc, since it is something that I do not know, Thank you. https://ibb.co/ftKWLf https://ibb.co/hqqGmL https://ibb.co/kLirLf
jomi
jomi
38.143
hace 6 años
Could you take out the top cover and upload a photo?
jomi
jomi
38.143
hace 6 años
It looks like an old amplifier for peripheral
ken09
ken09
2
hace 6 años
Good. but this type of amplifier only serves for MIc mode, and it will have another type of function such as connecting a guitar in the front input and putting some type of speaker in the rear outputs, it can be used or it is only for peripheralization.
Thank you.
pr122
pr122
10.397
hace 6 años
hace 6 años
notice here http://i68.tinypic.com/9k6q9l.jpg
ken09
ken09
2
hace 6 años
Thank you.
pr122
pr122
10.397
hace 6 años
Everything can be done, as long as you respect the impedances of both input and output, the latter is very critical, and you must respect it because if you place more speakers in parallel, the impedance low and you can burn the amplifier, to connect more speakers you must use the parallel series method, so as not to modify the output impedance, at the microphone input you can connect a guitar without problems, you can even modify the input for other applications, greetings
ken09
ken09
2
hace 6 años
Thank you, very effective your answers.
Regards..
