Professional Audio
V-Mixer M-400 Roland
xmvlife
xmvlife
27
hace 6 años
hace 6 años
Someone has the outline of this table, or better the service manual. thanks in advance
jomi
jomi
38.143
hace 6 años
The manual I have weighs a lot. Are you interested in any particular stage?
xmvlife
xmvlife
27
hace 6 años
hello, the tensions of the source and if there is a way to start with the panel board disconnected and the connections of this board with fader 1 and fader 2
Thank you
xmvlife
xmvlife
27
hace 6 años
... I get a start error "Recognition error of" panel, fader1, fader2 "... and I don't know if it's the central board or the board panel or the fader? .... or any tension that is wrong, thanks again greetings
jomi
jomi
38.143
hace 6 años
I will send you the source first
If you need something more you warn me
xmvlife
xmvlife
27
hace 6 años
ok, I'll see and tell you something
xmvlife
xmvlife
27
hace 6 años
hello, already tested all the tensions all ok ... in this table you can access in test mode ... but I don't know how ... it will come in the manual?
xmvlife
xmvlife
27
hace 6 años
it still doesn't start me ... you can send me the panel board scheme
jomi
jomi
38.143
hace 6 años
Do you have any number? to locate it well
xmvlife
xmvlife
27
hace 6 años
I have to disassemble it to access it but I think it says "Board Panel" ... I still send it to you when I disassemble it completely. okay
jomi
jomi
38.143
hace 6 años
hace 6 años
CPU Board Panel Panel CPU Board Diagram This panel block diagram Block Diagram Panel Source Diagram Roland M-400 Source Diagram Roland M-400 Source
jomi
jomi
38.143
hace 6 años
Confirm if it is what you are looking for
xmvlife
xmvlife
27
hace 6 años
Hello, it is the "CPU BOARD PANEL" that I am looking for. regards
xmvlife
xmvlife
27
hace 6 años
hello, well I do not do a good thing with this table, I do not enter test mode and I have the doubt if it is the board "panel cpu board" or the board "CPU board" gives me recognition error panel on screen ... but I have the doubt that if I disconnect it, I should start the system, right?
xmvlife
xmvlife
27
hace 6 años
surely there is the problem in the "CPU board", since I have seen a small scorched ic but I can't see the reference
xmvlife
xmvlife
27
hace 6 años
I already got the cpu main scheme ... thanks anyway for your input
