Professional Audio
homemade amplifier with sound distortion
joan castillo
hace 6 años
hace 6 años
I have an Chinese amplifier brand audessb with transceiver d1047 and the draybe c9014 the flaw that presents is that after changing the audio transistors one channel sounds good and the other channel sounds distorted at half of the sound and checked all the transistors resistance voltage of the source is ok the bias voltage 0.50 and has changed potentiometer and input capacitors and there is still a fault that gives me a clue to see if I isolate this fault thanks
Yunior Delgado Blanco
hace 6 años
Is it a balanced source?
joan castillo
hace 6 años
If brother already removed the distortion it was a 5401 transducer with leakage but it warms me very much the d1047 transistors of a channel
hace 6 años
the outputs are from pyn couples? ...
Alfredo G
hace 6 años
hace 6 años
The D1047 are those of the exit? If so check the components associated to the circuit of the bases of them because they are heating without having an audio signal, look to see the diodes in series between the bases or a transistor or thermistor that works in the bias ,,,, Regards.
