Professional Audio
Sansui ta 300 tuner / amplifier.
walterenduro
hace 6 años
hace 6 años
Good day. I have a doubt with my sansui ta 300. I feel that it warms more than other amplifiers. It can't be and I suggest checking to lower the temperature to an acceptable level. The device ginites well only this concern if it is within the normal range. Thank you
Quintero4hson
hace 6 años
hace 6 años
Hello friend Walterenduro, if the amplifier has the original speakers, you would have to measure the impedance of them "8 ohms" in each one, if the impedance is below what was indicated that would be a reason or if you change the speakers "speakers" in bulk wattage that would be another cause or that has added more speakers to the amplifier, if the speakers have piezoelectric twitter and are overheated or short that would be another reason. An easy way to counteract the amplifier's overheating is to adapt a "fan" heat extractor so that the amplifier works without any risk of overheating. Greetings from Valledupar Colombia.
walterenduro
hace 6 años
Alright I will keep it in mind. Thank you. Regards
Quintero4hson
hace 6 años
Hello friend Walterenduro I am glad that my opinion can be taken into account.
