From the power stage, it sends a signal to SPEAKERS at points 1 and 4 on CN104, from there it drifts for headphones (via R501 and R502) and for the output terminals but before reaching them it goes through the keys that enable the A and B systems, did you try to throw abundant contact with these keys? otherwise, you will have to measure and compare the components you have just before the output terminals. Everything I indicate is on page. 15 to the right. Try a fixed tone on some input, 1Khz for example, and measure with a VAC tester and compare. Count the results
Hi Mauridd, from what you see in the diagram, the same signal that reaches headphones comes to Speakers, there is no amplifier or stage or operational special for Phones, we would have to confirm that in Phones you also measure that uneven tone, obviously if you measure Just on the PHONES jack you are going to measure millivolts but in the same proportion, to avoid confusing one channel with another you should set the tone only in one input for ex. right and measure on the jack, with the balance in the middle obvious, and then connect the tone on the left input and measure on the other pin of the jack to confirm unbalance. S
There I cut the part of the diagram of speakers and phones, obviously in the photo you put the components that the diagram says do not appear ... it will be another version of manual or equipment ... if also in phones it appears uneven then I would see what it indicates The Colombian colleague. Luck and tell how you do
