"... For example if you run your tweeter unprotected and turn off the low pass filter by mistake, it will be a very costly mistake ..." Refers to the DSP's low pass filter. Not from twitter.
Excuse me Angel Morales, I do not understand when you say that it refers to the dsp low pass filter and not the tweeter, could you explain me better please?
ROMACI2005 already explained it and the document that links is a manual of another DSP. A low pass filter can be constructed for any frequency. The "low-pass" reference does not accurately imply the "high" frequencies of the audio spectrum. The term is relative and can be applied to both audible and non-audible frequencies, for example radio ones. I pass you a link where you can corroborate it.
http://www.learningaboutelectronics.com/Articulos/Calculadora-de-filtro-paso-bajo.php
Use a high value in Megahertz and another value of R, C and voila, you will see a low-pass.
Thanks Angel Morales, to all who participated equally, they have helped me, and now I understand the filters better, but I will read and reason all this and forward, please tell me what is appropriate now, to finish the topic I have to choose an answer right?
