What is the plate? possibly if it was over powered and you will change all the working voltages at the different points of the board, in addition to 72 when you rectify and filter it equal rises to 82, what you could do is use a single phase of the amplifier leaving it at 36, that when you rectify it and filter it the same reaches about 50, that is worth it if the plate does not use symmetric tension.
Haber, the transformer is 36-0-36 3 amp. Alternating current.
The board is for an audio power of 130w. Asking for an income of 50 v.
When you make the diode bridge and the capacitor, bone rectification and filter, you think it will reach 41 volt approx.
Is this preferable to greater tension? let me know and long.
hello brother FIRST is absolutely right, do not target 72v because you are going to break several components greetings
Yes, the question is that if I give only one channel I will not kill the transformer in a short time.
