Professional Audio
phonic 620 plus console speaker connection
Diegomar
Diegomar
214
hace 6 años
hace 6 años
IMG_20190818_103314540.jpg [2.71MB] hi good day, buy a Phonic enhanced console 620 plus with two 10-inch phonic passive speakers, I wanted to know if it is possible to add or connect an active speaker independently (jbl bt 12), the latter is powered but has an input, I wanted to know if it is not damaged when connected or if the phonic console It has some specific output to connect an active speaker since the jbl sounds much better than the phonic but it is active, thanks
hace 6 años
hace 6 años
Hi. You can connect any audio output from the console to the audio input of the amplified speaker. What if, that this output is controlled in level (volume) by the console so you will handle everything from it. Regards
Diegomar
Diegomar
214
hace 6 años
Thank you very much servimat as always. Even if the console and the speaker are boosted, where am I going to connect it too? No problem that both are enhanced? Attached photo of the entrances and exits
hace 6 años
There would be no problems because we are talking about signals and not power. I was telling you to connect the active speaker to a controlled output so you can control the volume of only one place.
Diegomar
Diegomar
214
hace 6 años
Do you have any idea what the controlled output of this console would be? I uploaded photo of the outputs, is phonic 620 plus powered model and the active speaker is a jbl bt 12
Diegomar
Diegomar
214
hace 6 años
the console has 2 outputs that say main and monitor behind and but forward rec out and moni and main but I do not want to burn the jbl speaker so my doubt if the boosted signal comes out I don't know
hace 6 años
Main and Moni are output for monitor and for another function but they are always signals. Never power. The power or the enhanced part of the console is for the connection of speakers. On the other hand there could not be a boosted channel without load because yes. Always connect with very low levels or volume.
Diegomar
Diegomar
214
hace 6 años
Thank you very much servimat !! It has Moni and main behind that says speakers (speakers) and forward Moni and main. Do I connect them in the front to the active speaker? (Enhanced)? Thanks
hace 6 años
Put it on anyone who has individual volume control or with general volume control.
Diegomar
Diegomar
214
hace 6 años
Thank you!!
hace 6 años
A pleasure as always.
Quintero4hson
hace 6 años
hace 6 años
Hello friend Diegocriterio try connecting at the back of the console where it says output in the terminal identified as main audio output to the amplified cabin. um_powerpod620_plus_r_en_es.pdf [3.33MB] Greetings from Valledupar Colombia.
Diegomar
Diegomar
214
hace 6 años
thank you! but that output has no power? I say not to burn the speaker that is also enhanced
Quintero4hson
hace 6 años
That is why I provide the user manual to read the instructions for use and you have no doubts, if you read point 10 of the manual you will realize that this is the connection indicated for audio output "line" to an amplifier and other devices external
Diegomar
Diegomar
214
hace 6 años
perfect, excuse me that I do not understand much of audio and I do not want to piss it off, you tell me that this output of point 10 is the ideal for an active powered speaker? thank you
Quintero4hson
hace 6 años
If the power output is set correctly, it is indicated in point 11 of the user manual as speakers, if you still have doubts about the terminal that you indicated it is easy to clear them by connecting one of the speakers in the terminal that indicates, but listen with power The sound is because the signal is minimal and it is to connect other devices as indicated.
Another audio connection is the one indicated as rec out on the front of the console.
Quintero4hson
hace 6 años
Always rehearse with a low audio signal and then to your liking.
Comment results.
Diegomar
Diegomar
214
hace 6 años
thank you more than anything I had doubts because some tell me everything that with an enhanced console you can not connect to a speaker that is active
