Professional Audio
Speaker Leea - model 8/12 HF - 8 ohms tweeter or woofer?
faradio75
faradio75
292
hace 6 años
hace 6 años
I have this speaker, whose power is between 10 and 12 W. The diameter is about 21 cm. The issue is that it has a broken membrane, and I can't prove it correctly. As a general rule, what I would like to know is if the diameter determines the inches, and if according to the size it can be determined with a certain approximation if it is a tweeter or a woofer, beyond which the first reproduces the treble and the second the bass .
Quintero4hson
hace 6 años
hace 6 años
Hello friend Faradio75 the diameter of the speakers are measured in inches in the case of which you refer is 8 inches and it is most likely the woofer if there is no other larger one in the equipment. Greetings from Valledupar Colombia.
romaci2005
romaci2005
4.485
hace 6 años
hace 6 años
The Leea - Model 8/12 HF is an 8-inch woofer, the tweeters are sealed by the back
