Professional Audio
How to repair yamaha htr5280 amplifier
Ep
Ep
Ep
2
hace 6 años
hace 6 años
Hello friends I have a Yamaha htr5280 amplifier turns on and off. Sometimes once and sometimes lasts longer. I am technician with a lot of experience in sound equipment but this problem I could not solve. Please request your colaboracion.gracias.
JLMRNEO
JLMRNEO
1.750
hace 6 años
regards ! which ah revised it?
EVELIO RIOS H
hace 6 años
hace 6 años
Friend the first thing is the diagram: http://diagramas.diagramasde.com/audio/Yamaha_RX-V800_RDS_HTR-5280.pdf What voltages are in the source when the equipment does not turn on?
Ep
Ep
Ep
2
hace 6 años
hace 6 años
I have already exhausted all my recurdos voltages are correct in the source. I have changed some capacitors but I have not been successful. The problem is that I'm not sure where the fault is. This happens to all yamaha. It seems to me that they are made with a limit of life because everything is well and suddenly that problem appears. If someone solved it I would like to see it.Thank you
EVELIO RIOS H
hace 6 años
Friend voltages in the source when no power is on? there is no variation
Ep
Ep
Ep
2
hace 6 años
The voltages in the main source measure well are 60 - + .but the source is multiple.
