hace 6 años
Best regards, my friend, are the positive 45 volts present? and the 45 negative volts that polarize the A1943 transistors are present? if they can not be the fault that does not amplify for lack of this voltage that polarizes them, you must measure the voltages in the collectors of each transistor and those of the pre where the fault can be also. regards
