hello friends a consultation I have a 50oh woofer or 4ohm woofer connected to a good amplifier I want it to sound like a subwoofer, if I put a passive crossover for subwoofer would work or better buy a subwoofer speaker and connect it to my amp will sound like or I have to add something else thanks
hello check if your horn has a wavy suspension to the shore you can use as a woofer, the amplifier if you have electronic crossover buttons like lpf and control it if you can use it ... a better electronic crossover or failing an epicenter. all this depends how much you want to spend although doing so you will hear well
almost cualkier epeicentro does the same ... the brand will depend on what you want to spend although there are many cheap and are similar with the good as the purpose is the same
If you do, you'll like it. but if you choose to put an epicenter you like the sound more because you can handle it to different sounds in the genres of music. is your choice!
the sound that will make the epicenter is very similar to what an earthquake does ... originates on one side and impacts on another ... I do not know if I define correctly what I mean by that his name is like that.
friend then in summary to validate the response of the amplifier I connect the epicenter and then any speaker that has that suspension and undulation that you mention will work as an original subwoofer speaker true
friend I forgot if I amplifier is 200w and I want to put a woofer of 4 omh and it is 10w (converted to sub woofer) as I would to have the amplifier do not ruin the woofer I have to add it.
