A trick when you do not know the code to program a universal control for x tv, is the following. Press the key to enter the code and there you begin to press the button to turn off several times until the TV turns off, when it turns off, do not press the button to turn off or the code will be changed again for another TV model. When the TV has turned off you must press the button again to place a code so it will be saved.
