Remote controls
universal control janesong js 3002a
Alexander S. vargas
my Janesong JS-3002A control is deprogrammed and I don't have the manual
elektorman
Try this sequence. Once the TV is turned on, press SET + POWER until the LED is on Then press VOLUME + until the TV shows some function on the screen Once the control has been synchronized with the TV, you record it with the SET button. [/List]
rafatell
nobody knows anything that's the truth
emilio 1977
just leave the set button pressed permanently ... it will begin to flash when the volume is turned up on the TV release the set button ready ... ... tube the same problem
Rogergemelo
Hello, all you have to do is press SET until the volume appears on the TV, release it immediately and then you give Lock and go!
walter armando rivera
If it was done as colleagues have said and it does not work you have to change control
martinezhardware
make sure brother that you have good the tv sensor try another control if you manage to grab the tv if you grab it is your control that is no longer useful to me also the same thing happened to me and what ise was to change the control because those controls are not good quality that's my little contribution greetings
martinezhardware
be sure brother that you have good the tv sensor try another control if it manages to grab the tv if it grabs it is its control that is no longer useful to me also the same thing happened to me and what ise was to change the control because those controls are not of good quality that's my little contribution greetings
sorelvis
hello excuse me my control janesong js-3002a doesn't want to work with my tv someone could help me ah come back ah program my control eh I do the same as the teammates say, I leave SET pressed and I get the volume and press lucked but still doing nothing could help me what else can I do thanks
