Then proceed to disassemble it carefully if you have no knowledge ... take out the rubber with the contacts and clean them well with isopropyl alcohol once done that grab an aluminum foil those that have cigarettes inside and cut them to the extent of contacts of the control you hit them with the droplet in those contacts of the changer, you close the control and try .. I would have to walk walking friend ... if it served you put it as an accepted solution
Sorry, obvia the guarantee ... it is also very easy to do .. you know if it happens to you with any control that has no guarantee haha ..
