TV and Video
tv noblex 29tc676f the timer is not removed
melena2017
hello friends, the tv in question is a noblex 29tc676f the problem is that the timer is not removed and in 10 minutes the tv goes out in service mode but there is no option do what you do always appears the timer on the screen and turns off in 10 minutes apart also appears stereo and the channel number and is not removed if someone knows why that happens if you can please tell me from now thank you very much everyone
R.E.Z
R.E.Z
3.644
Change the eprom with the tv data.
melena2017
Yes, my friend, I will change it because I already thought it was an eprom problem but I wanted to be sure, thank you
melena2017
Another one asks about the same TV, there is no audio or video input or back or forward and the TV has no audio, you say that it can be a problem of the eprom also those failures
R.E.Z
R.E.Z
3.644
If it is very likely
melena2017
ok thank you friend
