TV and Video
daewoo tv does not turn on
Televisor Daewoo TV DAEWO
mello
mello
150
Good companions I have a TV daewoo DTB 14V1FS that does not turn on, I made the measurements and according to the k2564 it is damaged and it measures continuity between pin 1-3. and measures between its pine 1-2 and 2-3 ... change it to a STP6NC60FP and nothing that turns on, what can I do? I hope you help me
mello
mello
150
note: I'm new to electronics, trying to learn a little
neg2013
neg2013
14.048
What chassis does the TV use? Is the DTB 14V1FS model correct? ... If the transistor is short, it will always be found around the component in poor condition too ... You have to work with a lamp in series to avoid greater evils at the source.
mello
mello
150
if the model is correct, the chassis would not have to check it ... where do I put the lapara in series?
mello
mello
150
this is the chassis CN-001A
neg2013
neg2013
14.048
If you found the MOSFET transistor in short, it is very likely that the hybrid IC is in poor condition too ... Check fuse resistors, for example R804 ... Check the D822 avalanche diode ... Serial lamp is a working technique for Repair the switched sources of the TVs, there are other methods, but I learned only this method. You have to build on basic repair skills at least to receive a guide, otherwise it is very complicated to work like this.
mello
mello
150
I already investigated the lamp in seie, you have to put it in series to the power to the TV, tomorrow I measure those components and I will warn you
mello
mello
150
Good morning bro, check the diode and it's good, the resistance is red-violet-gray 2.7 teraonhm .. I don't know how to measure it because my multimeter reaches 200M and the icon you say I don't know what it is, if you give me the code or the number as well as the diode is easier to look for ... thanks
neg2013
neg2013
14.048
Ok, the resistance that I told you before is of very low value, you are wrong in your appreciation about the unit ... The value of it is 0.27 Ohms on the 1X analog tester scale enough to measure it, in The scale of 200 in the digital testers is enough and left over, if resistance is not measured at these scales, it is because it is open. The IC is a hybrid DPM-001TI ... This IC is scarce, and if there are any they are very expensive ... If you do not have solid knowledge in the matter, and it is very complicated to assist ...
Luck.
mello
mello
150
thanks bro, if the resistance is open, and I know which one you say ... tomorrow I buy the resistance and the amount and I tell you ... for the knowledge I am starting on this bro but I learn fast .. thanks for your help and patience
mello
mello
150
ready bro I bought the resistor and the TV worked thanks for your help and patience
neg2013
neg2013
14.048
Well, I'm very happy .... Many successes in all your future repairs ...
mello
mello
150
write in giving solution to give you punctuation bro .. and I hope to continue learning since I am very excited about this
neg2013
neg2013
14.048
If you found the MOSFET transistor short, it is very likely that the hybrid IC is in poor condition too ... Check fuse resistors, for example R804 ... Check the D822 avalanche diode ...
