hello good afternoon victor. I told you I changed a transistor in the source that was open and now the voltage delivered by the source is 136 max in stanbye when power drops to 120 and the source is protected
what will it be?
thank you in advance
I commented victor I found a diode at the source and I can't find any data on it ... it has .oo457 ...
this one measures badly with leaks and I don't know what type it is ..
with respect to the fly I disconnected it and put 70 w bulb and does the same
. that's why I went back to the source
thanks friend for your time .. tomorrow I will continue to see what happens. a hug then I tell you
friend victor FIND THE FALLAAAA. .. I tell you that q642 (c1815) to replace polarized wine at the source around .. I do not explain why?
checking and comparing another I realized that the original is NPN and the one I put is PNP ... I want to die ... now it's on and ten half an hour ago
With respect to the Chottky I got a replacement for an amp ..
Thank you for your time from Etruria. Cordoba Arg. I leave a hug ...
