TV and Video
tv hypson of 34htv-c23nfs
jose alberto palacios2014
companions, good night. I need if you can help me with a HOPSON 34HTV-C23NFS tv chassis NM2968 030331 It has the bad BSC29-Z701 flyback and I don't get it and I don't replace it either, but I have a BSC 27-Z703B that takes it out of a HYPSON 25 TV with chassis of similar characteristics of echo the horizontal stage is equal to that of 25 TV, therefore I put the flyback of the TV from 25 to 34 and the TV works but I get late lines and low contrast being that I take all the attention to the TV and they are correct and I want to know if it might be the lack of power from one flyback to the other thank you for your help, thank you very much Atte Jose
Meygil2017tecnico
Friend an important point is that when replacing a flyback of another chassis you must first verify that all the pins described on the board match the board where you are going to place it ... and the inches of the TV ... greetings friends ...
yordansosa
Amigo verifies that he has the video voltage that is 180 or 200 vol and checks the abl stage, maybe some component for the other bad flybak is good.
Comrades, thank you for answering my messages, how I commented that the connections are the same and the voltages too, my doubt was to know if there was a difference from one flyback to another since one goes on a TV of 34 and another on one of 25, both They work with the same voltages and have the same characteristics, but physically one is bigger, which logically is the TV of 34 and well the difference in size is what we find if it influences.
Atte José
yordansosa
friend I have put flybak of tv rca of 21 in haier of 29 although the legs do not match I adapt when there is nothing more and it has already served me well biem now what can happen is that your flibak does not fill well in kvol the 34inches.
