TV and Video
tv filis model 21pt6437-44 has burned piece
Electronica Lorenzo
Happy night, colleague for everyone, I'm repairing a TV philis model 21pt6437-44, this colleague TV seems to be that the light went up and I burn the R402, and the C405 filter, abel if it is possible for a colleague to help me and tell me how much they are your values, and so you can keep fighting with this philis tv, your help will be of great value to me, many blessings my colleague,
master96920182018
Friend resistance 402 has a value of 56 ohm at 1/2 watt and c405 is 100 uf / 25 volt I hope I helped you friend ...
Electronica Lorenzo
grace my colleague have a happy day
Electronica Lorenzo
Happy late colleague, I am checking the chassis mount both the filter and the resistance and do not want to turn on this regulating it has the power voltage 4.7v turns on the stamp reading when I give it to turn on the lee goes off it has voltage on the horizontal collector too in the draive but do not want to turn on colleague, this TV filip are a bit complicated, any idea please, it will be well revived, thank you very much
master96920182018
I recommend you check the transistor Q845
Electronica Lorenzo
grace colleague already check
