TV and Video
noblex 21 tc 677u does not turn on
Elvio
Elvio
15
hace 6 años
hace 6 años
tc 677 does not turn on in stan by le das power and flickers the led does not start comes out 70v take out horizontal tr I put a light but does not turn on 70 v they get lost it remains at 0 v and change the str and lomism if anyone can help thanks
carlosm155177
hace 6 años
In stand-by of 70vol in operation it is 110volt, it can be the optocoupler, the ci of the vertical, I usually disconnect pin 23 of the micro jungle (PF = POWER FAIL source failure) and if it starts you can see what happens on the screen, also usually has false contact in the flyback especially the pin heater
manolo karvalo
hace 6 años
hace 6 años
Hello Friend. check the tsh. and do the following at the source, change the small filters and the opto coupler and if it is the tl431 change them, and check the zener diodes, resistors and after the choper check the filters and diodes may be undervalued, and solve the choper pins and those of flayback and the pins of ic. vertical, other cold welds you see on the plate. regards
Elvio
Elvio
15
hace 6 años
thanks to all of you and principally to manolo who has given me good steps to solve the problem
solve changing elopto and filters thanks a lot
