hace 6 años
Hello, as Manolo indicated, when in a TV the image narrows horizontally, the problem must be looked for in the Vertical Stage. As indicated by the colleague, look for that stage on the board and proceed to solve all the pins, also with the Flyback. Then if you have a capacitor tester, test if the electrolytic ones are dry, if you don't have it, proceed to its change directly.
Regards
