friend. I don't have a diagram but I found that data according to the model and the chassis number.
friend. but first check the polyester capacitors that are close to the tsh. because you have to look for the because he burned the tsh. I had until it could be the flayback and yoke that are short
Friend Manolo told you that I placed the tsh d-2499 that you had suggested not before reviewing components associated with it and the TV started perfectly. Thank you very much for your recommendation and I value you as the best solution. Greetings and I finish the post.
