TV and Video
lg tv 42lb5800
Sergio2013tecnico
hace 6 años
hace 6 años
Hi, I have a lg 42lb5800 tv the light of Stanby turns on 3 times and the TV does not turn on. I already measured the voltages at the source I have 3.5v, 12v, 24v. I did a visual inspection and nothing abnormal is observed. What I do notice is like a sibildo on a plate that is just above the power button. Thank you
Sergio2013tecnico
hace 6 años
Hi, I just checked the LEDs and if I have 9 LEDs burned
Thank you
ArandaVictor
hace 6 años
I'm glad that ayas solved, good luck friend.
ArandaVictor
hace 6 años
hace 6 años
Check the panel lighting LEDs, most likely you have one short
