TV and Video
Tv toshiba cs20e26 blurred image lack of focus on flyback
Televisor Toshiba CS20E26
Jorge Rivas
hace 6 años
hace 6 años
THE TOSHIBA CS20E26 TV PRESENTS A FAILURE IN THE IMAGE, THE POTENTIOMETER OF THE FOCUS IN THE FLYBACK IS GRATUOUS, AND GETS WORST AT THE TEN MINUTES OF IGNITION IS CLEARED AND IS DISCLAIMED WHEN SHUT DOWN AND GET IT BACK TO ME HELP WITH THE SOLUTION
Javier Honduras
hace 6 años
The socket causes this problem when it has corrosion when removing the focus cable from the socket it looks green indicating that the socket is bad change the socket and you will solve the problem
Jorge Rivas
hace 6 años
I THANK YOU FOR HELP REPLACES THE SOKET AND THE IMAGE SEES SHARP THANKS FOR THE ANSWER
Javier Honduras
hace 6 años
Excellent Jorge you are already making progress
Javier Honduras
hace 6 años
hace 6 años
Greetings change the socket of the insert that goes on the screen
