TV and Video
External TGW antenna for tda channels does not work
Dante Hernan
hace 6 años
hace 6 años
Hello people. Some time ago, a year or so ago, I bought my grandfather an antenna so he could watch open digital television channels (tda). Soon it stopped working. I climbed it to an old tower and the problems were over. Two months ago, only one channel is seen and at times. I tried everything but there is no case. I took my grandfather's TV to my house and all the channels are seen, which leaves me with a great doubt: will it be the antenna or the coax? Any input will be well received. Thank you!
Victor E
Victor E
65.783
hace 6 años
hace 6 años
You should check the continuity of the coaxial cable, which makes contact with the antenna. Normally bring a small transformer (balun) that couples the antenna with the drop cable. It usually burns and the antenna is inoperable. Check all that. Greetings
Dante Hernan
hace 6 años
Thank you Victor. In my case the antenna does not bring a (balun) but a black box with an integrated one. I don't have a multimeter but tomorrow comes a friend who has that tool and I'll measure the continuity of the cable. Thank you in advance for your response and I told you that I bought cable with the respectful connectors, just in case.
Regards
Victor E
Victor E
65.783
hace 6 años
check the black box, it may not be working and does not allow you to receive the tdt signal. do not forget to rate.
Dante Hernan
hace 6 años
Victor: thanks for the data. Nothing worked; In short, I bought a new coaxial and an impedance adapter. The antenna was 100% operational. Regards.
Victor E
Victor E
65.783
hace 6 años
Ok, greetings
