TV and Video
14-inch cyberlux brand TV 34BI chassis
rafael quintero
hace 6 años
hace 6 años
Good evening friends, I have a 14-inch television brand cyberlux chassis 34BI, there was a low of light, after the normal energy arrived I went to turn on the TV and the screen was opaque, and the LED light, just remained blinking, I uncovered it What situation did it present, take out the p6nc90zfp regulator, because I had doubts but when taking action it was ok, after replacing it, I decided to turn it on but the fuse burns it can help me in this problem to see what the cause will be
nicomena2015
nicomena2015
9.501
hace 6 años
hace 6 años
hello buddy: if the fuse burns check the rectifier bridge if there is no diode in short ... check the Q801 mosfet in source if it is not short ... remove the Q402 from the clamp to see if the + b of 103v is restored in C825 of 47mfx160v ... check ptc ... and oscillator of source lc801 ... in these cases it is necessary to connect a 200w filament lamp between the tv and the electric network or in the place of the fuse to avoid possible short in the source and not damage components ... if there is short the lamp will illuminate to the maximum ... greetings!
rafael quintero
hace 6 años
ok the fault was in the diodes of the rectifier bridge, now the led light turns on but when I turn it on the screen turns on but very opaque and the led light is blinking frequently
nicomena2015
nicomena2015
9.501
hace 6 años
the image has the tv ... the OSD or menu appears on the screen .... it works x A / V or video with dvd ,,, it has sound ... measure if the voltage of 180v is present in the C423 of 4, 7mfx250v ... and if it reaches the socket of the tube ... measure q. voltage has on pin54 abl ... on lc101 or microjungle ... measure screen tension in the socket of the tube ...
rafael quintero
hace 6 años
a question a filter of 33ufx160v, what would be its replacement
nicomena2015
nicomena2015
9.501
hace 6 años
it can be 47mfx160v .... according to where it is connected ... if it is in the line of + b it is fine ...
rafael quintero
hace 6 años
thanks friend the problem was in the rectifier diodes of the primary bridge and the 33ufx160v filter of the + b solution line completed.
rafael quintero
hace 6 años
hace 6 años
Thanks to you, friends, they have always helped me in the doubts and they have been very effective and sineras the help of you I was able to solve the fault I was in the primary bridge the damaged rectifier diodes and the 33ufx160v filter of the leaking + b line, replace it by a 47ufx160v capacitor and the TV works perfectly for me.
